S-10 & Blazer 1982-2005
2000 Chevy Blazer 2 door interior lighting issue!
Old Jan 27, 2020 | 9:23 AM
Christopher Sumrall's Avatar
Default 2000 Chevy Blazer 2 door interior lighting issue!
When the "passenger" door is opened the radio will shut off but the interior lighting will not activate? I am assuming both circuits are controlled by the same door jam pin... Anyone else come across this? Where might be the problem?
P.s. All functions work as it should when opening the "drivers" door. Dome overide also works as intended.
Old Jan 27, 2020 | 10:52 AM
There is a switch that when activated will keep the interior lighting from coming on no matter what the door switch does. make sure this is not your problem.
Old Jan 27, 2020 | 2:36 PM
Irish_alley's Avatar
I'm here for the party
like chevy is saying theres a push button on the headlight switch. does your dome light come on at all?
Old Jan 27, 2020 | 7:06 PM
Original post was slightly edited please re-read.. thanks for your replies!
Old Jan 27, 2020 | 9:53 PM
the door switch itself has 3 contacts, i cant say for sure but i imagine when the door is open two contacts are touching (something like A and B) then when the door is closed two are touching (something like A and C). so killing the radio might be from A and C touching while the light might be from A and B. and theres just an issue with the "B" terminal but not the others. you could go to the parts store and get one and test it with an OHMs tester and compare it to yours.
seams like the switch is a spdt (Single Pole Double Throw)
jimmydriver
Aug 23, 2018 2:56 PM
bstrobel88
Oct 9, 2015 12:19 PM
aleshaj
Jul 21, 2013 7:38 AM
jsadler
May 15, 2008 8:45 PM
gphillips2
Jan 6, 2007 4:17 PM
