S-10 & Blazer 1982-2005
2000 chevy blazer front diff
Old Aug 13, 2015 | 4:09 PM
Kevin Lawson's Avatar
Default 2000 chevy blazer front diff
guys I have a 2000 chevy blazer ls 3 button 4wd system...I push the button for 4hi or 4 lo light comes on sounds like everythin is engaging the cable that comes from under the battery pulls for,the front end ...but there is nothing going to the front tires I have crawled under it and in 2 wheel the axle that's goes to the front turns by hand then when I put it in 4hi or 4lo and,put it in park I cant turn the front axle by hand...and it does turn while vehicle is moving. In 4hi or 4lo but still nothing...I'm at a loss don't know what else to do
Old Nov 25, 2015 | 6:27 AM
Camronj's Avatar
I am having the same problem with my 2002 Chevy LS s10 zr2. Have you found a resolution? If not, on my s10, In 2hi the front axle doesn't spin. In 4hi and 4lo it does spin. The cable your talking about under the battery goes to an actuator pump and as long as the drive shaft is engaging the actuator is good. I hear that it could be the hubs in the front dif or you might have to just get a new front axle/dif.
Old Nov 26, 2015 | 11:20 PM
edac's Avatar
4x4 Front Differential Operation Explained & Grinding from Front End - S-10 Forum
Kevin Lawson
Aug 13, 2015 4:00 PM
tim_cleav
Jan 29, 2014 8:01 AM
Ronsuburban
Jun 22, 2013 2:22 PM
2004urb
Oct 21, 2007 2:23 PM
Faith_plus_1
Mar 2, 2007 3:17 PM
