S-10 & Blazer 1982-2005
2000 s-10. Cel
Old Sep 30, 2010 | 7:41 PM
TimboSlice's Avatar
Default 2000 s-10. Cel
Hello all,
I am in the market to buy a used 2000 Chevy S-10, and the guy I am buying it from says that there is a check engine light on, and that's it's caused by one of the cats. Is this possible or is it just an excuse? Any help would greatly be appreciated.
Thank You
Tim
Old Sep 30, 2010 | 8:41 PM
stock s10's Avatar
It is possible for a CEL to be caused by a cat but more likely it is an o2 sensor or something similar. Knowing the actual code would clarify whether or not it is an easy or cheap fix.
Old Sep 30, 2010 | 9:13 PM
MDTAHOE's Avatar
Professional Mechanic
Most likely he is telling the truth. It probably has a PO420 catalyst efficiency below threshold bank 1 or PO 430 catalyst efficiency bank 2 (if it is a 6 cylinder). You need to have the computer scanned for code to be sure. If it does not run bad that is most likely the case.
Old Oct 1, 2010 | 7:54 AM
TimboSlice's Avatar
Thanks for the quick responses fellas. He said his uncle ran the code, so I just emailed him asking what the specific code was. I'll get back with that.
I'm really just want a pick up to use as a beater and hauler, and I've always loved the s-10. I drive a slightly modified 2005 TL, and I don't like driving it in snowy weather, and I'm starting to do some handyman work, so having a truck is crucial.
It's a 2000 S-10 Xtreme Pickup, 4cyl, auto, 2Dr reg cab, black with 134k on the clock. He's asking $2800 OBO. Does this sound reasonable?
Also, is there anything else that I should look for that is notorious for problems on these trucks?
timdogg1313
Jul 18, 2011 6:43 AM
wildman
Jan 6, 2009 8:20 PM
rickybobby
Aug 12, 2008 7:38 PM
burnowt00
Jul 1, 2008 3:50 PM
redhotneon
Apr 16, 2007 10:31 AM
