S-10 & Blazer 1982-2005
2001 Chevy S10 4WD
Old Dec 6, 2022 | 12:03 PM
RichardSch3's Avatar
Post 2001 Chevy S10 4WD
I have a Chevy S10 4WD no fire when cranking over, it will start eventually after working key from run position to cranking position a few times, I put a timing light on the coil wire to see if it was firing it only flashed 1 time when cranking I replaced the ignition switch, distributor, fuel pump, crank sensor, and relays I'm stumped, It will start up with starting fluid and once it gets warmed up it will start every time except when it sits overnight, fuel pump pressure is around 60psi. when it runs no missing runs smooth, I don't think its plugs, I'm beginning to think the spider injection system is going bad?
Old Dec 6, 2022 | 8:09 PM
oilcanhenry's Avatar
How about when it wont start? Any fuel pressure, as 60 PSI is normal.
Old Dec 7, 2022 | 12:16 PM
yes fuel pressure is normal
Old Dec 7, 2022 | 9:24 PM
That's good to hear, RichardSch3. I would get the OBD II codes read at an auto parts store, or purchase one and see if any codes show up. If you post any here, we will have a better way to diagnose your Chevy S-10 pickup.
Killglass
Oct 16, 2015 12:04 AM
chevytrucks4life
Dec 11, 2014 8:43 AM
gbenn1970
Mar 30, 2014 12:34 PM
Joewill2848
Apr 22, 2012 8:12 PM
cameleon10
Dec 14, 2007 8:05 AM
