S-10 & Blazer 1982-2005
2001 S-10 codes
Old Nov 6, 2009 | 3:48 PM
antivelkrochica's Avatar
Default 2001 S-10 codes
Does anyone know what, if anything, would cause a P0442 (small evap leak) and a P0137 (low voltage to the O2 sensor) at the same time?
I've had an issue with both codes before, but usually separately. The last time I had a P0442 code, the shop boys told me I had a pin sized hole in the filler neck, so I replaced the whole thing from the tank to the cap. That was probably 6 or 7 months ago now. The O2 sensor code has come on before, and had turned itself back off before I had it looked at. Any suggestions for either one or both? Thanks!
Old Nov 7, 2009 | 7:17 PM
nauticstar87's Avatar
with the p0442, i have the same code in my 07, i suggest a new gas cap and go from there. For the o2, im not sure.
Old Dec 5, 2010 | 8:29 PM
jetncomptech's Avatar
Default same issues
I had the same issues with an 01 malibu and the o2 sensor actually had a short in it finally started to let the majic smoke out changed it no more codes
austforfb
Mar 16, 2014 12:24 PM
austforfb
Mar 11, 2014 8:57 PM
rabbit0102030
S10 & Blazer DIY and Useful Threads
Mar 5, 2014 7:36 PM
jnshullihen
Jun 8, 2009 7:11 PM
ingolenssen
Nov 22, 2007 11:14 AM
