S-10 & Blazer 1982-2005
2001 s10
Old Oct 21, 2009 | 2:00 PM
sweet4evr24's Avatar
Default 2001 s10
the four wheel drive i get no lights on the push button four wheel drive switches i tried changing the switch still the same problem what do i do next
Old Oct 23, 2009 | 2:09 PM
Siliconasp's Avatar
You need to have the computer scanned for code errors, pretain to this issue. Also you might need to have the actuator check for failure.
Old Oct 24, 2009 | 11:38 AM
Default thank you
for the ideas. i don't have a scanner to scan the drive train so it's goin next week to the shop to be check thank you again
Old Dec 5, 2010 | 8:25 PM
jetncomptech's Avatar
Default try this one
My 2001 blazer did that and it was a vacuum line off near the upper center firewall on some sort of small valve , replaced the line no more issues. Another part of the vacuum lines runs under the battery box & you have to take the box out to get to it.
nab_pwner
Apr 16, 2022 12:02 PM
Fliver
Jan 28, 2016 9:12 PM
fastfirebird
Nov 10, 2006 5:20 AM
jagblazer01
Aug 18, 2006 1:55 AM
