2001 S10 Right Front Issue
2001 S10 Crew Cab ( electronic 4wd )
While driving down the road, and out of the blue and not consistant, My truck will start making whine/ zipping sound
sounds seem to be coming from the right front side, while driving in normal 2wd. Noise slows down as the veh slows,Once I press the 4wd the noise will stop but even then I can hear a clicking as I make a turn. but the whine / zip sound stops. This issue happens at random, I have had the Shift Cable replaced, Wheel bearing assembly replaced and the actuator/ hoses replaced and this issue is still happening, Any ideas on the probable causes would be greatl appreciated
thxs
thxs
Did anyone have a answer fir this? Im having the same issue. Was told it was the wheel bearings, replaced the hub assembly its doing it again..
thxs
thxs
thompjs
Jul 6, 2015 11:18 AM
Bearpaafishin
Aug 11, 2014 7:34 AM
