S-10 & Blazer 1982-2005
2002 Chevy S-10 running rough
Old Jun 19, 2012 | 6:54 PM
Drew B's Avatar
Default 2002 Chevy S-10 running rough
I replaced the fuel pump in my truck about 2 months ago, and i guess i didn't get a good seal on the top with the o-ring. My check engine light has been on ever since with the code P0440, but today it just started running rough, and while i was on the freeway the check engine light started blinking.. I got the truck to limp home, having to keep it above 2000rpm at idle to keep it from dying... when i got home i read the codes, came up with 4: P302, P0440, P0302, P0440...any suggestions on this?
Old Jun 20, 2012 | 6:04 AM
Cylinder #2 misfiring. Check everything associated with #2 cylinder. Spark plug, wires, dist cap, injector etc. It would also be a good idea to fix the seal at the top of the tank.
Old Jun 21, 2012 | 12:16 PM
Drew B's Avatar
yeah, i know, i really do need to fix that seal on the tank. do you think that with it not having a good seal, and the pressure being messed up that it could have affected the injectors?
Old Jun 21, 2012 | 7:29 PM
If the pressure is too low then it definitely will affect the injectors and the engine. I don't think the seal would because I have left the cap loose by accident and the truck ran great. It did throw a code.
Old Jul 10, 2012 | 6:17 PM
Drew B's Avatar
I just wanted to write back and say thanks for the advice. I ended up changing out all my spark plugs and wires, then i was throwing code for multiple cylinder misfire. So then i decided to change my distributor cap, and that fixed the problem. Thanks again!
macmommy
Apr 22, 2020 1:23 PM
Scott6712
Jul 21, 2015 2:35 AM
Mechanicman
Apr 25, 2013 10:49 PM
circlenbar
Dec 11, 2012 6:42 AM
stanman
Oct 6, 2012 6:50 PM
