S-10 & Blazer 1982-2005
2002 s-10 cruise control stopped working
Old Jul 20, 2011 | 11:22 PM
CeS's Avatar
CeS
Default 2002 s-10 cruise control stopped working
Hello,
I have a 2002 chevy s-10 stepside that had the cruise control go out about a month ago. Could anyone tell me what all is involved with that cruise system? Could it be a relay that went bad?
Thanks in advance,
CeS
Old Jul 21, 2011 | 1:28 PM
EinST's Avatar
There's no relay. The cruise control module is powered through the 10A Cruise fuse in the I/P fuse block. Keep in mind that it will not engage if it senses the stop lamp switch is closed (automatic transmission) or clutch pedal cruise cut-out switch is closed (M/T).
Old Jul 23, 2011 | 10:49 PM
CeS's Avatar
CeS
what do you mean by the stop lamp switch? Also, could the ABS system have anything to do with it because my ABS light is on.
Old Jul 24, 2011 | 10:25 AM
EinST's Avatar
Hmm, I guess I get too literal sometimes. Does "brake light switch" work for you? When you depress the brake pedal, the switch closes and causes the brake lamps to turn on in the back. The cruise control module taps into the switch circuit to disengage the cruise when the switch is closed. As to the ABS warning indicator, the EBCM also taps into the switch circuit to activate only when the switch is closed. A switch that's permanently stuck closed will cause an illogical condition in the ABS operation. However, you can't be sure that's the culprit unless the trouble code supports the diagnosis.
abunker111
Mar 27, 2021 7:50 PM
Oldtruck2006
Jul 30, 2015 5:00 PM
et41143
Apr 13, 2015 3:12 PM
usmarine0905
Aug 25, 2013 9:41 PM
rjoos
Jun 28, 2007 6:59 PM
