S-10 & Blazer 1982-2005
2002 S10 Blazer brake light problem
Old May 30, 2011 | 5:35 PM
jdmckinney's Avatar
Default 2002 S10 Blazer brake light problem
I have a 2002 Chevy S10 Blazer. When I hit the brakes the left tail light won't light up but if I have the right blinker on, the left brake light will come on. Blinkers work fine and fuses are good. Is there a recall for this problem or am I just missing something.
Old May 31, 2011 | 7:41 PM
lynnboy021's Avatar
sounds like you have a wire problem somewhere. get a good test light and someone to help you and remove the floor panels remove the tape and have your helper push/release the brakes till you find the wire and once you find the wire keep going till you found the problem.... you can not pigtail from the other side cuz it wont work.
Bulldog9539@gmail.com
Sep 4, 2011 1:54 AM
beckya99
Jul 12, 2011 12:29 PM
popp36
Mar 9, 2011 10:49 PM
linerunner
Aug 3, 2010 7:33 PM
fastfirebird
Nov 10, 2006 5:20 AM
