S-10 & Blazer 1982-2005
2003 Blazer LS
Old Dec 21, 2008 | 8:36 PM
dacop's Avatar
Default 2003 Blazer LS
Hey Everyone...new here!
A week ago I purchased a used 2003 Blazer 4x4 LS with 74000 miles on it. I purchased off a dealer and it only had one owner but I know nothing else about the history of this truck. Paid 4K for it here in NJ.
I recently had the oil changed and will be having the breaks looked at tomorrow.
Today, the Service Engine Soon lightcame on and I ran it to Autozone and the device said something about a bad MAP and some other circuit problems. Is this a MAJOR problem? Is it hard to fix/replace yourself? Where is it located?
Also, being that I dont know the history of the truck, what else should I replace or have checked ASAP?
Thanks!
Dan
Old Dec 23, 2008 | 11:41 AM
dacop's Avatar
Default RE: 2003 Blazer LS
I got the code, its P0107
Where should I go from here? Replace the MAP sensor? Does anyone know where this is located on a 2003 Blazer?
Thanks
Old Dec 24, 2008 | 4:11 PM
johndb's Avatar
Your map sensor has to be on your intake manifold somewhere,I am not familiar with 2003 so I cant tell you where. Also I personally change all the fluids when I buy a used truck cause then you know they are all clean(except brake fluid,Too much of a pain in the butt)even your diff fluids and transfer case.
Eddie02780
May 11, 2015 5:19 PM
stshadow
Apr 22, 2011 9:48 PM
phmiller
Apr 27, 2010 7:08 AM
phmiller
Sep 19, 2006 6:02 PM
unixmonk
Jul 17, 2006 6:10 PM
