S-10 & Blazer 1982-2005
4.3 issues dead #5 cylinder
Old Feb 28, 2007 | 4:34 PM
mullet's Avatar
Default 4.3 issues dead #5 cylinder
this is the 2nd 4.3 ive gotten wiht a dead #5 cylinder both motors had/have high mileage but seem to run good and have suffecient power none the less. the last motor i tore down and found NOTHING wrong with it. valves were good and functioning con rod was intact piston was in good shape everything was fine. since before the tear down i had replaced the rotor cap plugs and wires i knew that wasnt the problem either.
well ive got another 4.3 dead on #5 changed the plugs and plug wires cap all that good stuff still dead. im not going to tear this one down because i suspect nothing is wrong inside the motor because of the last time.
sdoes anyone know why these motors do this?
Old Feb 28, 2007 | 10:21 PM
shnormo's Avatar
Default RE: 4.3 issues dead #5 cylinder
Could be a bad fuel injector, bad cam lobe, or a vaccum leak or a bad O2 sensor
Gray_wolf_7
Feb 20, 2015 6:16 AM
hufflumi
Sep 23, 2013 12:15 PM
yagozotljb
12
Feb 8, 2010 10:10 PM
