S-10 & Blazer 1982-2005
87 2.8l Flooding
Old Feb 14, 2023 | 9:03 PM
Slick50's Avatar
Default 87 2.8l Flooding
Got an 87 2.8L S-10. I have been having an issue since the weather got cool. On start up, mostly when below 50 degrees, the engine will flood on startup. I know this because it boggs down and if you floor the go pedal it clears up real fast. The factory emissions manual states to floor it, if a flooding situation occurs. Back in September I did a tune up, cap, rotor, wires and plugs. While T/S this issue I have replaced the fuel filter, coolant temp switch for the ECM, map, iac, and tps. Yesterday I replaced the injectors, yet the problems persists. All of the replaced parts have increased the drivability of the truck. Also have checked for vacuum leaks, no leaks. Any ideas?
DevinOwnz
1988 - 1998 (GMT400)
May 10, 2022 7:15 PM
rrichey2
Jun 28, 2020 7:36 PM
doctorsevarg
May 31, 2014 10:23 PM
2oCHEVYo0
Aug 11, 2011 6:28 AM
s1helby1
May 19, 2009 5:00 PM
