S-10 & Blazer 1982-2005
88 chevy s10 blazer with shaking problem!!!
Old Feb 12, 2008 | 9:02 PM
jasont483's Avatar
Default 88 chevy s10 blazer with shaking problem!!!
hi, i have a problem with my s10 blazer.. it is shaking when it get to about 20mph and get worst as you speed up!! i checked the wheel bearings, brakes and rotors, harmonic balancer,and changed the clutch fan.. but everything but the clutch fan( i replaced it)checked out.. now i am thinking that it might be the torque converter!!! so i wanted to see if anybody had any ideas what it might be or tell me that i am right on the torque converter... thanks for any info you can give me!!!!!
Old Feb 12, 2008 | 9:17 PM
EvansBlue's Avatar
Default RE: 88 chevy s10 blazer with shaking problem!!!
You also posted this in general tech.... Check your tire balance and roundness first.
Old Feb 13, 2008 | 5:16 AM
troll646's Avatar
i owned a 88 s10 blazer too, and it would start to shake around 55mph stop then start again around 60mph. i asked around and someone told me to replace the u-joint on the drive shaft. so i did that, went to test it and it still did it. i asked my dad about it and he had no idea. about 2 days later he calls. he told me to drive the blazer and when it would start to shake press the brake but still give it gas. i tryed that out and the shaking did stop when pressing the brake. i called him back to ask what was going on he told me that it was the transmission going out.
not sure if thats the same problem you have or not i just wanted to throw out some more options for you.
Old Feb 13, 2008 | 8:38 PM
shawnvw's Avatar
Banned
It sounds like something is out of balance or out of round. check your u-joints, see if any weights have fallen off of the driveshaft, possibly a bent drive axle,(ever sideswipe a curb in the winter?), maybe aloose front end???....just a few thoughts
Old Feb 17, 2008 | 2:20 PM
jasont483's Avatar
i did recheck the ujoint on my s10 and found that they had come a little loose!!!fix it now it works fine!!!! thanks to all that replied to my post it was very helpful!!!!!!
TheDudeAbides
Nov 10, 2015 7:32 PM
rachel126
Feb 2, 2012 7:55 PM
joeywhite
Aug 25, 2011 11:21 AM
MEC407
Oct 28, 2008 6:01 PM
jasont483
Feb 17, 2008 2:16 PM
