S-10 & Blazer 1982-2005
88 s10 fuel system problems
Old Nov 11, 2007 | 11:08 PM
indyguy1986's Avatar
Default 88 s10 fuel system problems
OK. My 88 S-10 2.5 tbi motor wont start, code says it's due to an ICA valve and mixture control solenoid. Those were replaced, still no luck. So I replaced the fuel pump. Herein lies the problem, when the fuel pump is in the gas tank, it wont run. When outside the tank runs perfect, found out it was because of the float on the sending unit, the further the float is moved up, the slower the pump goes until it finally just shuts off, so that means the sending unit is bad right? Well the other problem is when everything is hooked up and the ignition key is turned, NOTHING, the fuel pump wont kick on no matter what, what is causing this? The relay was replaced along with the computer. So why wont the key kick the fuel pump on? What is left to replace?
Old Nov 12, 2007 | 7:22 AM
DAVID L. PAUL's Avatar
Default RE: 88 s10 fuel system problems
did u check to see if inertia switch is tripped
Old Nov 12, 2007 | 12:27 PM
No I haven't. Where would that be located?
Old Nov 14, 2007 | 7:15 PM
It doesn't have an inertia switch. I'm out of ideas to try.
jstnbyd5595
Sep 23, 2012 4:13 PM
surfandride
Jan 16, 2011 10:05 PM
gigawiz
Dec 5, 2009 11:51 PM
Billy_225
Nov 18, 2007 5:20 PM
jadams1968
Jun 13, 2007 8:29 AM
