S-10 & Blazer 1982-2005
Fuse/bulb in charging system 85 s10 Blazer
Old Oct 4, 2007 | 2:55 PM
Billy_225's Avatar
Default Fuse/bulb in charging system 85 s10 Blazer
Anyone know of any bulbs in the warning light system that would put the alternator in 'no-charge' ?? And where's the fuse that would do the same thing? I'm assuming in the main distribution box.
Old Oct 4, 2007 | 3:08 PM
sickvortech1's Avatar
Default RE: Fuse/bulb in charging system 85 s10 Blazer
hello billy-225, if you warning light in your gauges say 'no-charge' um there was a joke there lmao...
it could be a failling alternator, have the alt tested for free at a parts store. i really dont understand the fist part of your quiestion, but for the second part theres no fuse that i know of for the sevice light .
Old Oct 4, 2007 | 3:20 PM
Billy_225's Avatar
oh yeah no no...
what I mean to ask is... I've got the appearance of an alternator failing but it might be something less. I went to get an alternator. looked the replacement up online and it came with this intstallation alert... INSTALLATION ALERT! A blown fuse or bulb in the warning lamp circuit may cause a "no charge" condition.
I'm just looking for this fuse or this 'possible' bulb. There may bea bulb in series with a relay somewhere, or there may be a fused relay, or just a big fuse that would keep the alt from charging the battery.
Old Oct 8, 2007 | 2:53 PM
i just read up on the charging system in the haynes manual and it talks about two types of alts, si/cs.
the best two suggestions i can make are, buy a haynes manual from a local parts store or call a local chevy/gmc dealer that has sevice techs. thay will let you know about the fuse/light issue.
Old Oct 13, 2007 | 8:12 PM
GUS's Avatar
GUS
i used to have a 1984 chev s10 and my brake switch at the brake pedal short out and my alternator gauge was showing no charge changed the switch and came back ok
Old Nov 18, 2007 | 5:20 PM
ThomleD's Avatar
You mentioned that the brake pedal switch caused a failure of your voltage guage. The problem went away when you changed the switch, what happened when the switch was merly unplugged?
b_graham26
Uplander
Jun 12, 2011 12:34 PM
Hardin Thicke
Apr 15, 2009 9:17 PM
jadams1968
Jun 13, 2007 8:29 AM
dagwood
Jul 3, 2006 10:20 PM
