S-10 & Blazer 1982-2005
93 s10 blazer lack of heat new parts installed
Old Dec 3, 2007 | 9:45 AM
honda450's Avatar
Default 93 s10 blazer lack of heat new parts installed
i have a 1993 s 10 blazer with the vortec motor. I resently replaced the heater core cause it was leaking. Well now it's and my motor isn't getting up to temp. I have replace the thermo stat and a new pressure cap. With no luck, I installed a temp gauge cause the dash one wasn't working. When driving down the road it's reading 170 then goes up to 180 and back down to 170.
I am thinking of a possible fan clutch that is stuck on. Is there a good way to test a fan clutch. LOL the guy at the auto parts store said to grab a hold of it while it's running (which I said sounds like it's hard on the fingers).
Old Dec 4, 2007 | 8:10 AM
John86's Avatar
Default RE: 93 s10 blazer lack of heat new parts installed
r u sure ur thermostat isn't stuck open even tho u just replaced it?
Old Dec 4, 2007 | 3:02 PM
DAVID L. PAUL's Avatar
sounds like u installed a 180 degree thermostate i wouldn't worry if its running that temp and everything operated ok
Old Dec 5, 2007 | 7:10 AM
honda450's Avatar
I was going to go buy a GOOD thermostate and replace it. It use to run for 15 mins and blow good hot air. and the mileage is crap now with it.
Old Dec 5, 2007 | 4:22 PM
then get factory oem thermostate and install and b sure to bleed coolant system good when filling back up with coolant should solve problem
clarkw61
Mar 11, 2013 10:35 AM
kc1976
Jan 18, 2012 3:41 PM
dereksavy
Jan 11, 2012 3:50 PM
Smkyb
14
Nov 30, 2010 11:46 PM
matthewstephenp
Jan 31, 2010 2:00 AM
