91 suburb 454 tbi lack of power pulling up hill
Old Oct 5, 2011 | 6:07 PM
clarkw61's Avatar
Default 91 suburb 454 tbi lack of power pulling up hill
lacking power pulling 4000 lb boat up hill.is there an after market tbi I should change to or any other ideas.thanks much clark
Old Oct 6, 2011 | 5:52 AM
shamrock246's Avatar
fuel pressure,cat clogged did it always do this or did it start recently
Old Oct 6, 2011 | 1:02 PM
clarkw61's Avatar
runs great all the time when not pulling the boat,but when pulling the boat up a good hill it just seems to be weak.not a stong puller up hill.runs great up hill when not pulling. 454 2wd 3/4 ton thanks for replying
Old Oct 6, 2011 | 1:53 PM
RacerX's Avatar
In Drive or Overdrive?
Old Oct 6, 2011 | 3:33 PM
ousig2408's Avatar
how many miles? that is an old engine that is probably pretty tired at this point so needs some TLC. even new I think those were around 235 hp and 375 tq and do you have the 3 speed transmission? if so that doesnt help any with towing...
but you need to let that beast breathe - go to jet.com or other aftermarket sites to replace the throttle body and intake manafold, then go to the exhaust - add headers, replace the CAT and make sure all of the exhaust pipes are sound or replace them
I used to have a 1990 single cab Chevy with the 350 and it ran VERY strong once I did those engine upgrades.
Old Oct 6, 2011 | 7:37 PM
clarkw61's Avatar
I always tow in Drive not O.D. , the engine has 96,000 miles on it.I just had it smoged (california)passed . The tech said sounds like not getting enough gas when pulling up hill, to change tbi as you say so I will check out jet.com . thanks for the replies clark been checking not much luck finding tbi for 454 I need to look more tomorrow
Old Mar 11, 2013 | 10:35 AM
SuburbanStevie's Avatar
Had similar problem on mine. turned out the little bushing type bearings on the distributor shaft were totally worn-out, causing the timing to be off as much as +/- 10 degrees...randomly! replaced the whole distributor for minor cost, and power change was amazing.
heavychevy511
Oct 31, 2012 8:43 PM
seastrike
Aug 13, 2012 11:39 AM
Smkyb
14
Nov 30, 2010 11:46 PM
matthewstephenp
Jan 31, 2010 2:00 AM
exChevyhater
May 25, 2007 2:33 PM
