S-10 & Blazer 1982-2005
94' chevy s-10 blazer 4.3 v6
Old Nov 16, 2006 | 7:21 PM
94 blazin's Avatar
Default 94' chevy s-10 blazer 4.3 v6
alright so heres da deal, i've done an oil change, new plugs and wires
new airfilter.... first started havin probs after i got gas from a place i usually don't... no more den 30minutes after gettin gas my truck starts to run real rough like it wanted to cut out, n would stay at a real low idle, till it would die... for a good hour i could get it started but it would jus bog down n die out
..... i ran it today and it would drive fine but after like twenty minutes of driving my service engine soon light will come on, y is that?
Old Nov 17, 2006 | 1:58 PM
uncle bill's Avatar
Default RE: 94' chevy s-10 blazer 4.3 v6
Take it and have the codes read, that'll give You the answer.
Old Nov 17, 2006 | 2:45 PM
dragonrpc's Avatar
I just posted a similar issue with me 95-
The main thing causing the check engine soon, adn extremely rough, hard to start, dieing, was the EV0? (not sure exactly the name of the valve) but it was a valvle at the intake manifold that was "Clogged" with carbon. that fixed the bulk of the issue
https://chevroletforum.com/m_11169/tm.htm
Old Nov 28, 2006 | 6:31 PM
splat's Avatar
it sounds like you gaped them off or mayby you bumped the end and shortened your gap.
Old Nov 28, 2006 | 9:57 PM
snarl2004's Avatar
If i were u ide check the fuel pump. Over the summer the place where i lived 3 of the 4 gas stations got bad gas and ruined the fuel pumps of every car that got gas from there. The gas company had to pay for the repairs but if i were u i would start of my checking the fuel pump and make sure u dont have bad gas.
Old Nov 30, 2006 | 1:22 AM
70mopar's Avatar
dragonrpc, i believe the valve u r refering 2 is the EGR, which can get clogged with carbon, & cause u a big headache (like u had).
Old Dec 1, 2006 | 10:06 PM
dragonrpc's Avatar
ORIGINAL: 70mopar
you are 100% right, just couldn't think of it at the time, EKG, ECG, EGR (glad you knew what I meant) [&:]
I have also learned in the recent weeks, that it is common for the 4.3 to run like crap due to injector clogs. several freind told me they add a injector flush to every tank or every other to prevent the headaches I went into (and the need to replace injectors when they get to bad)
Old Dec 2, 2006 | 7:14 PM
94 blazin's Avatar
well i appreciate eryones advice, recently the catalyc converted was shot into my muffler crinkling my muffler from the backfire, i took the muffler off and shook out all the excess honeycombs.... as far as the codes i could not find anyone to read it without chargin me out the *** so i went n did it myself the codes i'm gettin is the egr, no distributor refrence to the ecm, idle air control valve-which eryone keeps tellin me is a dealership part-but they have the one for carbeurated engines-go figure, and the map sensor... i replaced the mapsensor-it was like 45-50$, the egr was replaced a year ago-a new one will run me tween 150-200$..
so i geuss my only option is to replace the egr valve again, find the iac valve-install it, check the distributer to ecm...
if that doesn't cure my problem then imma get a baro sensor, feul filter, feul pump, injector, pcv valve, oxygen sensor, also minor oil leak on preassure hose from filter to engine...
then catalyc converter and a muffler...
yeah its alot but, i like my truck, n can't afford to get anyting else....
also once i replaced the tps it ran like a dream! but after driving for a while it would run rougher at idle n surge during acceleration to a point where i could only tap the gas to keep it from surging n dying out.... but hey it does sound alot better wit out da catalyc converter...lol i might have to get sum three inch deul flowmastrs to put on it...lol
cubangt
May 12, 2022 7:41 AM
Eddie02780
May 11, 2015 5:19 PM
stshadow
Apr 22, 2011 9:48 PM
