S-10 & Blazer 1982-2005
95 2.2l exhaust flange bolt inaccessible
Old Jul 6, 2014 | 4:57 PM
freakboy70's Avatar
Exclamation 95 2.2l exhaust flange bolt inaccessible
Hi everyone,
I'm new here and still getting a feel for navigation on this site. Bear with me, please.
I have to pull my manual transmission from my 95 s10 with a 2.2l. In the way is the downpipe, connected to the exhaust manifold. I got one of the spring-backed bolts, but the other one is blocked by the frame, downpipe, and various other parts. After searching the 'net for hours, I still haven't found a way to reach that one bolt. Has anyone had this issue? Is there a special tool? I'm at a hold up point and starting to reach "hurry up" mode... I referred to a Chilton manual, and all it shows is the easy bolt... they neglected showing the difficult one...
Any help is GREATLY appreciated.
Thanks in advance,
Steve
Old Jul 6, 2014 | 7:49 PM
sledge.impy's Avatar
Originally Posted by freakboy70
Hi everyone,
Thanks in advance,
Steve
Can you post a picture?
Would it back up into the frame if you did remove?
It sounds like a socket isn't going to work? Can you get a regular wrench on it?
Are your motor mounts bad and it's sagging on that side? Can you jack up that side any to move it some? I wouldn't recommend jacking on the oil pan - that won't hold up and you'll be more screwed.
Can you get a cherry picker on the top to lift it any? Maybe you a leveler to rotate it slightly?
Old Jul 7, 2014 | 4:52 PM
freakboy70's Avatar
Old Jul 8, 2014 | 10:36 AM
Yikes!!!
A shorty socket with some swivels won't help??
stanman
Apr 24, 2013 10:55 PM
wolfdogg
Sep 16, 2012 1:36 PM
rtarb41323
Apr 27, 2012 11:39 PM
hydrodriver
Astro
Jul 18, 2010 8:13 PM
cheburashka
Jun 19, 2007 10:37 PM
