S-10 & Blazer 1982-2005
95 S10 4.3 Computer Questions
Old Nov 25, 2007 | 8:57 PM
aj_wicked13's Avatar
Default 95 S10 4.3 Computer Questions
I have a 95 S10 (TBI) and i believe the computer is bad... the engine is not anywere near as powerful as it was. It feels almost as if the engine isn't controlling the timing as it should. the Computer is SN 16230703 Are there anyways to test this thing without taking it to the dealer? When i put it on a OBDII Scan tool it says "cannont associate with ECM." The check engine light is not on nor has it ever been even after 143K miles. I did have to replace the Intake manifold gasket at about 120K. but i set the timing back right were it was at 0deg at idle as the decal under the hood said.
Part 2. I will doing a fair bit of towing, and was wondering if i can put a mild cam in this engine and still use the stock computer and EFI setup. (can the computer compensate enough) I know my milage is going to go down, but I would prefer to keep EFI as this is my everyday driver.
Old Nov 26, 2007 | 9:33 AM
EvansBlue's Avatar
Default RE: 95 S10 4.3 Computer Questions
Make sure the wiring harnessis in good shape and the connector is clean and everthing and we'll go from there.
Old Nov 26, 2007 | 4:47 PM
That was the first thing i checked as well as all the fuses for the entire truck. none were bad.... Everything looks to be in Ok shape.
DJL2010
May 12, 2010 3:21 AM
magicc8ball
Feb 7, 2010 6:56 PM
2000s10sc
Dec 10, 2009 9:40 PM
JustMe
Nov 4, 2006 3:14 PM
