S-10 & Blazer 1982-2005
96 4.3 starting probs
Old Apr 29, 2011 | 7:30 AM
stshadow's Avatar
Default 96 4.3 starting probs
Ok I have a starting prob that i cant fig out have no codes listed. fuel pressure is 60 psi at key on, 58-59 cranking. Have good spark but it wont start. the only way to start it is using starting fluid or add fule to the TB then it will run just fine.
Old Apr 29, 2011 | 4:57 PM
EinST's Avatar
Are you saying "it will run just fine" afterwards or as long as it's fed the starting fluid? Try starting it with the MAF sensor disconnected?
Old Apr 29, 2011 | 7:18 PM
stshadow's Avatar
once it starts it will run and stayin on its own. I will try unpluging the MAF
Howell_kyle74
Apr 2, 2014 10:49 AM
vbob2
Aug 2, 2007 1:16 PM
talkinggoat
Oct 23, 2006 7:02 PM
bjthebetsig
Aug 26, 2006 12:24 PM
