S-10 & Blazer 1982-2005
96 Blazer Overheating Problems
Old May 1, 2007 | 11:44 PM
Zeusfan's Avatar
Default 96 Blazer Overheating Problems
I have a 96 Blazer with the standard 4.3L V6. It has a horrible overheating problem and I cannot find a cause. It has actually blown out 4 heater cores. The radiator has been changed, the thermostat has been changed numerous times, the water pump has been changed 2 times, the clutch fan changed and on and on it goes. It has 2 different repair shops baffled. Right now it doesn't have a thermostat in it. I took an old thermostat and cut the center out of it to restrict the flow of water enough to pull off the heat of the block. This worked for 1 day. Now after 5 miles it is overheating again. Strange thing is there is no overflow or coolant leaking from anywhere. Does anybody have any suggestions? Please help I don't need another driveway ornament, I already have my son's 83 Tbird.[&o][&o]
Old May 7, 2007 | 12:31 AM
twizzle12's Avatar
Default RE: 96 Blazer Overheating Problems
maybe a head gasket?? that would be my best guess.
Old May 7, 2007 | 10:21 AM
golfer's Avatar
You may also have an air lock.
norwalkfisherman
Aug 8, 2011 6:57 PM
linerunner
Aug 3, 2010 7:33 PM
jess1327
Aug 28, 2008 6:46 PM
rickyman
Oct 27, 2007 5:41 PM
jsbr5000
May 17, 2007 7:56 PM
