S-10 & Blazer 1982-2005
97 Chevy blazer misfire?!?!
Old Sep 24, 2018 | 10:07 PM
Twell47933's Avatar
Default 97 Chevy blazer misfire?!?!
i Have a 97 blazer with a 4.3 vortec motor. It has 208,000 miles and has a gutted cat and complete straight pipe exhaust. New fuel pump and filter in 2015. It has a misfire that comes in at about 1500 rpm and doesn’t really go away after that unless you floor it and it doesn’t miss. Doesn’t throw any codes either. This past March I did new plugs wires and cap and rotor. Yes I used oe Delco plugs and duralast gold wires and cap rotor. It also may be related but it keeps losing antifreeze. No leaks and it’s not in the oil either. It has a new radiator and thermostat to. I’m so lost with this if anyone can help me lead to something I’d appreciate it. Thanks.
Old Sep 24, 2018 | 11:19 PM
geo1's Avatar
EGR binding?when you did the wires,same problem was there before?
Old Sep 25, 2018 | 8:30 AM
Twell47933's Avatar
so your saying egr could b bad?
Old Sep 25, 2018 | 8:48 AM
geo1's Avatar
Possible,or pull plugs,check for a very clean one, possible cracked head or head gasket
Old Sep 25, 2018 | 4:50 PM
kevinkpk's Avatar
Compression check
Old Sep 25, 2018 | 5:48 PM
Twell47933's Avatar
Originally Posted by kevinkpk
Compression check
wouldn’t compression be fine if it fires up good and still has full power when in the throttle just has a rough spot when normal driving between 1500-3500 rpm where it sputters and misfires but doesn’t do it when floored or idiling
Old Sep 25, 2018 | 5:49 PM
Twell47933's Avatar
well the egr is still shiny so I think the previous owner replaced it
Old Sep 25, 2018 | 5:52 PM
geo1's Avatar
So much info. if you did compression check and plug check,process of elimination
Old Sep 25, 2018 | 6:13 PM
geo1's Avatar
I understand your questioning,but you brought up antifreeze dissappearing, makes me nervous,but,that not mentioned,a slightly different course,dead spot in tps or map gone flakey
Old Sep 25, 2018 | 8:35 PM
Twell47933's Avatar
im not sure it threw a code today for Evap flow during non purge whatever that means but I don’t believe it’s related. Still no antifreeze in the oil and no leaks. I thought it was a head problem but I don’t think so. Maybe intake gaskets? I’m so confused.
