S-10 & Blazer 1982-2005
98 s10 2.2 sfi Valve Cover Bracket Removal
Old Apr 10, 2021 | 7:41 PM
s10_'s Avatar
Default 98 s10 2.2 sfi Valve Cover Bracket Removal
I'm trying to perform a head gasket replacement, and wondering if any of you have run into this back bracket that sits behind the intake manifold, covering the back left valve cover bolt. The first two bolts go into the valve cover, but the last one sits on the bottom of the bracket between the engine and firewall. What tool can be used to reach this? Have any of you come across this before? Haynes manual says this is only on my specific year and model (what great luck). Any help would be appreciated, thanks!
https://i.imgur.com/U3xcOnx.jpg
Old Apr 11, 2021 | 3:07 AM
oilcanhenry's Avatar
From what I can see it looks to be broken off. I don't see any inside threads, so to get it out of there you'll need to buy a kit that removes broken off bolts.
Old Apr 11, 2021 | 12:27 PM
s10_'s Avatar
Those two bolts have already been removed. The one I'm speaking about is on the back side of the bracket between the engine and firewall.
Old Dec 29, 2021 | 8:28 AM
Mr_autlstim's Avatar
It is a 10mm I used a ratcheting 10 mm crows foot as you see in the pic. But it does not have to come all the way out it is slotted on the bottom.
Kasman
Jan 19, 2021 7:34 AM
nf123
Nov 10, 2020 5:45 PM
jft7032
Dec 31, 2011 8:43 AM
mastermosley
Dec 12, 2007 8:08 PM
Ameritrash
Feb 6, 2007 10:12 PM
