S-10 & Blazer 1982-2005
99' 2.2L won't start after head gasket replacement
Old Mar 23, 2010 | 3:20 PM
kapricorn62's Avatar
Exclamation 99' 2.2L won't start after head gasket replacement
Here's the deal...my 99' S-10 2.2L blew a head gasket almost a year ago, about 5 months ago i started the process of replacing the head gasket. got the head off, took it downt to be resurfaced and checked for cracks, it was all good..bought new push rods, bolts, gasket, spark plugs, starter battery, tps and finally got it all back together (with some help from a chevy mechanic)..went to try and start it...cranks but wont turn over. i checked the throttle cable and D'oh it wasn't routed the way it was suppose to be so i fixed that (wasn't opening the throttle body) the fuel pressure release was loose so i tightened that everything else is connected, but now the battery is low from trying to start it. .other than that, anyone have any clues as to why it wont start? (oh, put in new oil, oil filter & coolant) HELP PLEEEZE.. i been without my truck for almost a year! this is killing me! thanks..
Old Mar 23, 2010 | 6:19 PM
mudmaniac's Avatar
Ride of the Month
May 2009
My guess would be the orientation of the distributor is off.
Old Mar 23, 2010 | 6:30 PM
No distributor ...
Old Mar 25, 2010 | 7:21 PM
Rogers mechanical repair service's Avatar
Distributer or timing are off most common problem. Set No. 1 to TDC and check that the distributor post is pointing at the No. 1 cap post. Also check your timing, spark and fuel delivery. Pretty much backup and check everything.
Old Oct 1, 2011 | 7:34 PM
the1andonlydiego's Avatar
Default s10
first of all the 2nd gen s10 2.2l doesnt have a dizzy it has a D.I.S. ignition.......i had the same problem after head gasket replacement and it turned out to be a spark problem ......spark was gold color and not a blue ish ..........traced it back and the crank position sensor was faulty
Bugfuel
Jan 27, 2015 10:45 AM
Rdaniels
11
Jun 3, 2013 8:19 PM
expressvan00
Dec 6, 2010 12:29 AM
Stirgen
Feb 5, 2008 3:44 PM
