S-10 & Blazer 1982-2005
99 ABS light
Old Mar 27, 2008 | 9:06 AM
brianvm77's Avatar
Default 99 ABS light
Shortly after start-up ABS pumpcycles and ABS dash light comes on and stays on. Nolonger have ABS capabilities... Checked front sensors and are clean. Haynes Repair Manual says to check resistance and refer to specifications listed in manual but fails to actually have the specifications listed(not very helpful). Does anyone know what the resistance should be? Or any other suggestions as to what the problem could be? Also where exaclty is the rear ABS sensor on a 99 S10 4x4?
Any help is appreciated!!
Old Mar 27, 2008 | 5:49 PM
shawnvw's Avatar
Banned
Default RE: 99 ABS light
The rear abs sensor is non existant. The signal originates from the VSS. The PCM receives a speed signal from the vss, and sends a signal to the ABS module for rear wheel speed.
As far as resistance is concerned, I found this.....
WSS Temperature vs. Sensor Resistance (S-pickup)
°C°F Ohms
-40 to 4 -40 to 40 3915 to 5820
5 to 43 41 to 110 4769 to 6800
44 to 93111 to 2005560 to 8040
94 to 150201 to 302 6600 to 9416
Old Mar 28, 2008 | 10:15 AM
brianvm77's Avatar
Thanks for the chart, that is better than the Haynes manual offered. Lets hope I just have a bad sensor.
Is it common for the Vehicle Speed Sensor to go bad, and/or could that be causing the problem?
Old Mar 28, 2008 | 8:18 PM
shawnvw's Avatar
Banned
if your speedo is working then most likely no. If you don't turn up a bad sensor, it might be worth it to have the code scanned to see what the problem is exactly. Could be something as simple as a fuse or chaffed wire.
Old May 18, 2014 | 6:58 PM
dmap707's Avatar
Default nice
I have a 1999 k1500 suburban will this apply mine since i have very similar symptoms? Thanks in advance
kaptain howdie
Dec 16, 2014 8:20 PM
Bulldog9539@gmail.com
Sep 4, 2011 1:54 AM
Deteoni
Mar 28, 2009 1:39 PM
onetimeatbndcamp
Oct 10, 2006 1:16 PM
