S-10 & Blazer 1982-2005
AC Blows Warm While Driving
Old Feb 27, 2014 | 7:34 PM
sj2333's Avatar
Default AC Blows Warm While Driving
I have a 96 S-10 2.2L that the A/C blows cold while it's idling but when I start driving the air gets warm. Compressor still runs, just blows warm. Once I come to a stop light it gets cold again. Any ideas what can cause this? Thanks in advance.
Old Feb 27, 2014 | 8:31 PM
I am not familiar with this truck but here is a idea if the temp blend door is vacuum operated; maybe the loss of vacuum at cruising speeds is causing the temp blend door to move.
test this theory by reving the engine to 2500rpm, transmission in park, for 50 seconds and see if the a/c goes warm
Old Feb 28, 2014 | 9:55 PM
sj2333's Avatar
At higher RPM it does cut out, less air flow from the vents as well.
Old Mar 1, 2014 | 8:42 PM
there must be a vacuum leak or a bad check valve in the vacuum controls for the blend doors. maybe someone familiar with this hvac system will chime in.
motoxer4533
Cobalt
Feb 5, 2016 5:24 PM
Buckmaster73
Jun 28, 2012 9:09 PM
jennkent5454
Jan 12, 2010 5:41 AM
jd625
Jul 30, 2009 7:18 AM
