S-10 & Blazer 1982-2005
AC Problem 2000 Blazer LS 4x4
Old Aug 21, 2016 | 8:12 AM
1966thunderbird's Avatar
Default AC Problem 2000 Blazer LS 4x4
Hoping for some direction
Start truck and I can leave it idling in driveway for 1/2 hour and the ac cycles normally , nice and cool, ac clutch cycles normally.
Start out and within 5 mins the ac stops functioning. clutch does not cycle.
Shut truck off and start the next day and the ac works at first, then drive for a couple of minutes it stops
I have replaced the low pressure/cycling switch and connector checked all fuses in the fuse relay under hood and interior fuses a well.
Any suggestions would be greatly appreciated.
Cooking in the North 91 degrees.
Old Aug 21, 2016 | 8:16 AM
Have you checked the freon
Old Aug 21, 2016 | 8:31 AM
Yes, before changing the cycling switch.
Now even when you bypass the switch it still does not engage. after vehicles has been moving.
Would it still function for a 1/2 hour without moving if the freon is low,?
Anything electrical that might be the cause? common wiring issue with this model?
