AC Problems 2000 S10
I have a 2000 4.3L V6 S10 pickup. The AC is cold and does work, however, when I turn the AC on, the truck struggles to get to even 30 mph and guzzles gas like you wouldn't believe. Even if I wait until I get moving like on the freeway and then turn it on, you can just feel the truck suddenly struggling. The second I turn the AC off, the truck runs just fine. Is this an AC problem or an engine problem or what? Any ideas/help would be greatly appreciated.
How much does it struggle? Do you have a tach. on yours? If so how many rpms does it drop?
I have a 2001 Sonoma with the V-6 and you feel my compressor kick on.
It probably drops about 1,000 rpms. It just feels like something is really overworking itself so then I freak out and turn it off and the rpms instantly go back up and then the truck can move. It runs great until I turn that AC on for some reason.
Have you had the truck since it was new? My guess it that your a/c system has too much pressure in it. I would get that checked, other wise I would bet the bearings in the compressor is bad. It would be making alot of noise. I know you can get gauges at parts stores to check the pressure if you want to do it yourself
nab_pwner
April 16th, 2022 12:02 PM
fastfirebird
November 10th, 2006 5:20 AM
