S-10 & Blazer 1982-2005
air leak around throttle shaft
Old Sep 3, 2018 | 12:50 AM
Mous's Avatar
Default air leak around throttle shaft
94 s-10 was smoked and showed a leak on both ends of the throttle shaft. sealed back end w/ an o-ring but the front still leaks. am considering a few drops of blue thread sealant so there will be no gap. the question is: How could it wear there since that shaft has bearings? thanks for any wisdom
Old Sep 3, 2018 | 10:36 AM
It's 24 years old. Everything eventually wears out. You can take it apart and replace the bushings or get a rebuilt throttle body. Thread sealant won't work because it is a moving part.
Old Sep 3, 2018 | 11:34 AM
Mous's Avatar
Hi oldchevy:
The shaft has sealed ball bearings, sealant should fill any void between the inner race and the shaft but how/why is it worn there? w/ (sealed) ball bearings there should be no wear.
