S-10 & Blazer 1982-2005
Blazer loss of power up hills
Old Aug 27, 2017 | 6:43 PM
Maineiacer's Avatar
Default Blazer loss of power up hills
The blazer 4.3 4x4 shifts fine through all gears. But going up a hill it boggs down and will shift down to next lowest gear when it gets to 1st gear I have to pull over. If I turn it off and re start I can drive until it goes through this cycle of down shifting to 1st. All the time I'm climbing the hill the rpm's are up at 2 thousand, feels like I'm pulling a house behind me going up hills. Was running great on flat road now at around 40-50now it's starting to hesitate like the fuel pump is going bad but it was replaced 1-2 years a go. Did a scan and came up with a code for a bad shift solenoid . It shifts just as smooth as can be. I also had the transmission rebuilt 3 years a go. I'm at my wits end. Has new plugs, wires, distrbuter, Any help or suggestions would be greatly appreciated. Thanks too all in advance.
just added new fuel filter, catalytic converter, mass airflow sensor, I didn't mention even with gas pedal to the floor the rpm's never go above 2000-2200 to the floor is 2000 lift up on pedal just a bit and it will rise to 2200.
Last edited by Maineiacer; Sep 7, 2017 at 9:48 AM. Reason: New parts and still persis
Old Aug 27, 2017 | 8:12 PM
kevinkpk's Avatar
Rings?
Old Aug 27, 2017 | 11:09 PM
Maineiacer's Avatar
Default Rings.
There's no smoke out the exhaust or any loss of fluids. No sign of antifreeze in the Oil. The scanner has a shift solenoid code showing but it shifts fine up and down just no power. I really don't know where to look next. I'll ask my mechanic about the rings. Thanks for the reply.
Old Aug 27, 2017 | 11:12 PM
therewolf's Avatar
Sounds like a bad shift solenoid to me. Was it taking hills just fine, up until just now?
Old Aug 28, 2017 | 7:46 AM
Maineiacer's Avatar
Default Shift solenoid
It gradually got worse over time now it bogs down even on flat ground. But shifts fine up and down every gear smooth as silk.
would I be missing any gear with a bad solenoid??. Thanks for helping I appreciate it.
