S-10 & Blazer 1982-2005
Blazer starting problem
Old Sep 21, 2019 | 6:04 PM
Von Wolff's Avatar
Default Blazer starting problem
Hard to start unless I use starter fluid or fuel down throttle body runs great once started although sometimes have to turn on and off to eliminate rough engine
No one in my country knows how to fix this problem
Old Sep 22, 2019 | 12:22 AM
oilcanhenry's Avatar
What year, engine is your vehicle? Have you run a fuel pressure test? How many miles do you have?
Old Sep 22, 2019 | 7:59 AM
Probably the check valve in the fuel pump is bad and the fuel is bleeding back into the tank while sitting. You can replace the fuel pump or add a check valve in the fuel line. If the fuel pump is very old then your best bet is to replace it.
Old Sep 22, 2019 | 3:50 PM
Von Wolff's Avatar
Default 4.3 vortec
Hi I have replaced the fuel pump the fuel filter the injectors fuel pressure is great
runs real well The mechanics over here charge $100 an hour and they are not very good
Old Sep 23, 2019 | 5:50 AM
Craig0320's Avatar
Is it a tbi 4.3 or sfi. I have solved this issue before on the the sfi models by replacing the fuel pressure regulator inside the upper intake. It sits on the end of the main fuel rail where the big wire connector plugs in. They go bad which causes just enough pressure loss not to let the engine start on its own.
91_Blazer
K5 Blazer
Apr 22, 2013 8:42 PM
kenneybert
Dec 25, 2012 12:27 PM
mud cookie
K5 Blazer
Jun 15, 2012 7:50 PM
bms
Apr 8, 2010 2:29 PM
vhays
Apr 8, 2008 1:24 PM
