S-10 & Blazer 1982-2005
Blazer won't start
Old May 3, 2012 | 9:37 AM
jimmydriver's Avatar
Default Blazer won't start
Went out this morning to start my 2001 blazer and it won't turn over not even a click. Tried jumper cables nothing. Battery connections are good. The volt meter on the dash said it was getting about 11.5 volts without the jumper cables. No we did not leave any lights on last night. We did have 2 really bad storms come through last night and I'm wondering if it got struck by lightning. Pretty far fetched I know.
Old May 3, 2012 | 11:11 AM
Check the starter and the starter solenoid as the first step. Also check to see if you are getting voltage at the solenoid when the key is turned to start.
Old May 3, 2012 | 12:08 PM
stanman's Avatar
if a battery goes bad it will still say it has 11-12 volts but it wont produce any amps.
Old May 3, 2012 | 3:56 PM
I got it to start. I disconnected the positive cable for 20 minuted and reconnected it. It started right up. I have no idea why it did this.
Old Jan 11, 2015 | 12:12 PM
thestampman80@msn.com's Avatar
Have you had the problem again? the Same happend to me & it did it again. I let it sit until the next day & it started again. is there a solution to this problem? Pls confirm or direct me the the source to solve the issue. TXs. Mike.
Old Jan 19, 2015 | 10:19 AM
1995 chevy s10 blazer all is working, but when I went to strat it, nothing happened. sat for a day & it started. ran for 3-4 days & it did it again. new battery, alt. charging, new ignition control switch. pls help. can't figure whats wrong. THX MIke
rroyse
May 4, 2016 11:18 AM
bracca
Jul 12, 2009 6:14 PM
G&b
Jul 9, 2009 11:19 AM
kingster888
K5 Blazer
Mar 2, 2008 5:50 PM
