S-10 & Blazer1982-2005
Hi,
I have a 1985 S10 that needs drums. I ordered the Napa 440-1359 that fit ,but rubs on the backing plate. The old drums have a cast #14074862 which cross referenced to a Napa 440-1457 that looked correct, but of course did not fit (bolt pattern). These drums actually fit an Astro Van 1985 vintage. The Astro van drums and the original drums have a machined edge that fit into the backing plate to eliminate the rubbing. Is there a manufacturer out there that makes a replacement drum that actually has the machined edge for the S10 ? If anyone can help I would appreciate the help. Thanks Bob J Cast #14074862 S10 drum with machined edge Astro van drum that crosses with the cast # 14074862 has the machined edge but bolt pattern different will not fit S10 S10 drums new but do not have the machined edge Fit but rub the backing plate
