S-10 & Blazer 1982-2005
Brake drum issue
Old Jun 3, 2021 | 7:34 PM
trogg's Avatar
Default Brake drum issue
Hi,
I have a 1985 S10 that needs drums. I ordered the Napa 440-1359 that fit ,but rubs on the backing plate. The old drums have a cast #14074862 which cross referenced to a Napa 440-1457 that looked correct, but of course did not fit (bolt pattern). These drums actually fit an Astro Van 1985 vintage. The Astro van drums and the original drums have a machined edge that fit into the backing plate to eliminate the rubbing. Is there a manufacturer out there that makes a replacement drum that actually has the machined edge for the S10 ? If anyone can help I would appreciate the help. Thanks Bob J
Cast #14074862
S10 drum with machined edge
Astro van drum that crosses with the cast # 14074862 has the machined edge but bolt pattern different will not fit S10
S10 drums new but do not have the machined edge Fit but rub the backing plate
Old Jun 4, 2021 | 7:23 AM
Take the old drum with you to the parts store and see if they can match it.
Old Jun 7, 2021 | 7:24 AM
hogbiker's Avatar
try Rock Auto.com...they're pretty good @ getting you the right part for your year
garetmalcom
Feb 14, 2017 7:02 PM
Fliver
Jan 28, 2016 9:12 PM
kevinbarb
Feb 20, 2013 5:01 PM
TierSpass
Aug 24, 2009 1:03 PM
Smokies420
Aug 21, 2008 11:45 PM
