S-10 & Blazer 1982-2005
Brake problems
Old Oct 27, 2019 | 8:21 PM
Craftsman962's Avatar
Default Brake problems
I have a 96 S-10 4.3 auto when I press my brake pedal to the flr it sticks causing my brakes,to lock up when running. but when I shut motor off brakes an pedal releases what would cause this. Don't knw when they do lock up.
Old Oct 28, 2019 | 1:42 PM
maybe a bad booster....unplug the vacuum line to the booster and see if it works better....you won't have vac assist obviously
Old Oct 28, 2019 | 1:51 PM
Ok I will try this this evening. If my booster is ok u think it could b my master cylinder
Old Oct 28, 2019 | 1:53 PM
It especially does this n cooler weather not so much n warmer weather
Old Oct 28, 2019 | 7:36 PM
Brake booster is ok
Old Oct 29, 2019 | 11:59 AM
Irish_alley's Avatar
I'm here for the party
maybe the check valve is sticking open?
Old Oct 29, 2019 | 12:38 PM
Ok I will check that this,evening
Old Oct 29, 2019 | 12:49 PM
Im just going to replace the check valve an hose instead of checking an go frm there. That way i knw that part will b new.
Old Nov 1, 2019 | 10:56 AM
My rear drum brakes r acting strange when I come to a,stop going forward instead of coming to a smooth stop it grabs,an tries,to lock up it only does this on my left rear wheel could it b my wheel cylinder it's not leaking fluid.
Old Nov 1, 2019 | 10:58 AM
I checked my check valve it's working no air leaks. Never done this before.
