S-10 & Blazer 1982-2005
Carburetors
Old Jun 19, 2008 | 9:42 PM
Nicker's Avatar
Default Carburetors
I've got a 1985 2.8L 4 speed S-10, and it takes FOREVER to start when it's cold. I think it's choke on the carburetor but im not sure and I haven't got off my *** and really looked at it yet. I basically have to pump the gas really quick while my engine's turning, and then i have to hold my foot on the gas at around 4500 RPMs for a minute or two before I can let my foot off the gas and not have my truck stall again. Any idea what the problem might be?
Old Jun 21, 2008 | 9:29 AM
shawnvw's Avatar
Banned
Default RE: Carburetors
Before you crank the motor over, give the gas pedal one pump. That'll squirt a bit of gas down the throttle bode, and set the choke on. Crank it over, if it doesn't start right away, give it a few pumps....If it still takes forever, check out your fuel pump, make sure you have pressure, and good volume. Check the fuel filter. If the gas checks out ok, you may have to get the carb adjusted
Old Jun 21, 2008 | 4:35 PM
EvansBlue's Avatar
Check the accelerator pump on the carb as well.[/align]
HotRodRick
Chevelle & El Camino
Feb 17, 2015 8:23 PM
taharqa23
May 11, 2011 8:58 PM
