S-10 & Blazer 1982-2005
Check engine light on
Old Dec 10, 2007 | 6:09 PM
Outcastz89's Avatar
Default Check engine light on
I have a 89 s10 pickup with a 4.3L and four wheel drive.The other night it died on me on my way home because the battery was just about dead.Before it died on me the check engine light wasn't on.But right after I started it up it was on.I don't know where to start with problems.Does anyone have any idea where I can start or what the problem could be?
Old Dec 11, 2007 | 3:12 PM
EvansBlue's Avatar
Default RE: Check engine light on
Its letting you know your aternator is going bad.
Old Dec 11, 2007 | 11:36 PM
Outcastz89's Avatar
I'll put it on the alternator tester to find out for sure.Thing is I just got this truck.The alternator looks about brand new.Could it be because it was low on oil?I think I gotta replace the oil pan gasket.
Old Dec 12, 2007 | 8:00 AM
EvansBlue's Avatar
Its possible that it detected a drop in oil pressure and tripped the Check Engine light.
Old Dec 13, 2007 | 12:03 AM
Outcastz89's Avatar
That's exactly what I was thinking.
Old Jan 4, 2008 | 10:49 AM
quinnman105's Avatar
I would also still check the alternator. Even tho it may look like it's new it could still be charging the battery 100%. That happened to me
Old Jan 8, 2008 | 6:22 PM
northamfishing's Avatar
No expert here but I had similar problems with my s10 blazer. New o2 sensor and EGR valve fixed that problem. Test the alternator for sure.
redrotor
Cobalt
Aug 29, 2019 8:38 PM
o.valdez
Dec 17, 2011 10:46 PM
psd7.3
Dec 22, 2010 8:23 PM
101btp
Nov 30, 2010 8:36 PM
93chevyman
Mar 12, 2010 1:13 PM
