S-10 & Blazer 1982-2005
Chevrolet Blazer S10 ABS problem
Old Jan 17, 2025 | 3:25 AM
Mako1990's Avatar
Default Chevrolet Blazer S10 ABS problem
Hello All,
I would like to aks you for help, on my Chevrolet Blazer S10, 1995 the ABS light is on. What could be the possible causes? Is tehre any way I can identify the malfunction? I dont want to change something that doesnt have to be changed...
Thanks for any advice.
Old Jan 26, 2025 | 6:58 PM
damclean's Avatar
My 2000 S-10 had the same issue. Mine was bad solder joints in the ABS controller.
Old Jan 26, 2025 | 7:43 PM
Rednucleus's Avatar
My 93 Suburban had some codes, mechanic said would be spendy fix - light has been on for over 10 years, brakes work fine (just no abs)
Old Jan 27, 2025 | 9:17 AM
Mako1990's Avatar
Yes, my situation is very similar ABS light is on , but brakes works just fine, but I dont sense any kicking while braking so probably no ABS at all... Would this be the case if any of sensors are broke, or it look more like issue with ABS unit? Really dont know what should be my first steps...
Old Jan 27, 2025 | 9:38 AM
Rednucleus's Avatar
Get scanned for any fault codes
Old Jan 27, 2025 | 11:04 AM
Mako1990's Avatar
not possible, this is OBD1 so no chance to get someone with that old scaner and fault codes that car gives you when you bridge A and B socket in that connector give you only engine fault codes, I think....
Old Jan 27, 2025 | 4:12 PM
Rednucleus's Avatar
My 93 codes were scanned by our mechanic
Old Jan 27, 2025 | 4:49 PM
Mako1990's Avatar
Just learned that its possible to get that abs fault code by connecting A and H socket , so Am gonna try that tomorrow and we’ll see…
Old Feb 2, 2025 | 4:29 AM
Mako1990's Avatar
Ok guys I used a paperclip on ALDL to connect A pin and H pin and here are the codes :
86
28
12
35
31
37
33
65
66
I cant believe there are so many!! Maan I just hope that I can repair it somehow, maybe it would be easier to replace the whole ABS system 😂 can you please help me decipher the codes? I cant find anywhere , what these codes stands for…
again Am having 1995 4.3 Blazer S10 142kW with 1GNDT win code
thanks for any advice!
jbur373190
Feb 7, 2012 2:53 PM
Hilario
Mar 17, 2009 3:54 PM
hardbody300
Nov 6, 2007 3:55 PM
Ryan Markt
Jan 28, 2007 9:39 PM
