S-10 & Blazer 1982-2005
Chevy S10 4WD
Old Dec 6, 2022 | 11:26 AM
RichardSch3's Avatar
Post Chevy S10 4WD
Thanks for letting me in.
I have a Chevy S10 4WD no fire when cranking over, it will start eventually after working key from run position to cranking position a few times, I put a timing light on the coil wire to see if it was firing it only flashed 1 time when cranking I replaced the ignition switch, distributor, fuel pump, crank sensor, and relays I'm stumped, It will start up with starting fluid and once it gets warmed up it will start every time except when it sits overnight, fuel pump pressure is around 60psi. when it runs no missing runs smooth, I don't think its plugs, I'm beginning to think the spider injection system is going bad?
Old Dec 7, 2022 | 9:11 PM
Welcome to the forum. I'm moving to the S-10 section of the forum where you will get more views.
RichardSch3
Dec 7, 2022 9:24 PM
chevytrucks4life
Dec 11, 2014 8:43 AM
Joewill2848
Apr 22, 2012 8:12 PM
cyberrkatz
Jul 22, 2010 9:48 AM
cameleon10
Dec 14, 2007 8:05 AM
