S-10 & Blazer 1982-2005
do i need to shim the starter
Old Sep 17, 2013 | 5:04 PM
trentenmarschel's Avatar
Default do i need to shim the starter
ok ill start with the last time i replaced my starter i had to use shims in order to keep it from making a high pitched whining sound. since then i just replaced the pilot bushing, flywheel, clutch,pressure plate, and the throwout bearing and hydraulic cylinder. but now when i put the truck back together it sometimes make a bad grinding sound when i start the truck i did leave the same shim i had in there before but with the new starter should i take the shim out or put more in.
bavant
Jan 16, 2012 2:12 PM
77chevy1
Mar 11, 2010 12:13 AM
freedomfighter_87
Dec 7, 2009 7:32 PM
freedomfighter_87
Dec 3, 2009 6:30 PM
j_mangus
Jul 29, 2008 3:35 AM
