S-10 & Blazer 1982-2005
DTC P0301
Old Oct 20, 2006 | 9:56 PM
temills's Avatar
Default DTC P0301
My 1998 S10 with the 2.2L started running rough with an intermittant miss. Most days it starts up and runs okay; others it misfires from slight to really rough. After running a while the misfire disappears. At first I thought it was happening when started cold; now it happens regardless of whether it is cold or hot. The shop installed new plugs and wire set, changed fuel and air filter, and new pvc. I get a code P0301 from the computer. Any suggestions would be greatly appreciated.
Tem
Old Nov 2, 2006 | 11:21 PM
NCHEVYHEVN's Avatar
Default RE: DTC P0301
Are you getting fuel injector pulse at the fuel injector? Do you have a noid light?
Old Dec 16, 2006 | 3:16 AM
frazprg's Avatar
I looked it up, P0301 is cylinder 1 misfire. The codes list appears to show that all cylinders have a misfire code so I think it narrowed it down for you already. Im reading a guide and It states you basicly check how your spark is going on cylinder 1 and possibly all of the cylinders. It could lead you down to a poorly firing cylinder and perhaps a bad coil pack (im assuming with the year) or maybe even a bad pcm, the guide points at a faulty injector if the spark is good. Oh! and I see a bad head gasket can start kicking these codes out, I know some guys who ran into this kind of stuff with a similar chevy motor before.
I know this post is old but It sounded like your on the road to alot of problems and I wanted to chime in if It wasnt too late.
Old Dec 16, 2006 | 6:35 AM
kcb37's Avatar
You may want to check your injectors. If it isn't getting fuel it wont fire causing the comp to think you have a misfire.
Bobcat1963
Nov 19, 2012 8:05 PM
halverson82
Jun 19, 2011 9:51 AM
Mud_Truckin
Sep 12, 2009 7:32 PM
calwoodbutcher
Jul 31, 2006 2:07 PM
calwoodbutcher
Jul 28, 2006 5:14 PM
