S-10 & Blazer 1982-2005
Fuel Gauge 1/4 Tank or less
Old Mar 16, 2011 | 7:53 PM
waltd140's Avatar
Default Fuel Gauge 1/4 Tank or less
So at 1/4 tank or less my fuel gauge moves everywhere between 1/4 & empty. I don't know when I am really empty & the 'low gas' light comes on.
I heard about a TSB about this. Got TSB PIT-3046E, 3046A, 030849014A, 030848014 but cannot find the fix for it. Called a Chevy dealer & asked about the 1st number & they said there was no record.
Can anyone tell me the fix for this?
Old Mar 17, 2011 | 11:25 AM
EinST's Avatar
The 03-08-49-014A dated Oct-03 says to program the PCM with new calibration. I find it hard to believe the problem is just noticed. The culprit is probably the sending unit.
Old Mar 19, 2011 | 6:54 AM
waltd140's Avatar
This has been going on since I got the truck (used) about 2 weeks ago. So where would I go to do that calibration?
Old Mar 19, 2011 | 8:41 AM
EinST's Avatar
Check with your local dealership service department? They'll probably want your VIN but you'll want to make sure they understand that the PCM may not be original.
Old Mar 23, 2011 | 3:12 AM
waltd140's Avatar
Sounds like my plan. Thanks for the assist
Old Jun 15, 2011 | 11:33 PM
harrison420's Avatar
my 2000 blazer has a similar problem in addition when im at a 1/4 tank or below i must be parked on a level ground or nosed uphill or it will not crank as if its not getting fuel if pushed to a different position it cranks right up, i was told by an ase master tech that a baffle in the fuel tank my be broken and the fuel sloshes around more than usual, i just live with it and mind where i park when 1/4 tank or lower.
M10027m
Aug 29, 2014 9:18 PM
mangomanj
Aug 17, 2014 9:51 PM
annamarie
Sonic (Aveo)
Jun 27, 2012 7:50 AM
M-21
Apr 15, 2011 5:32 AM
