S-10 & Blazer 1982-2005
Fuel gauge/battery light failure 99 Blazer
Old Oct 13, 2006 | 11:30 AM
Hal Maulden's Avatar
Default Fuel gauge/battery light failure 99 Blazer
I have a 99 s10 Blazer, 4.3L, 80K miles. Last week the fuel gauge failed, the battery indicator came on, the temp gauge failed, and the light that indicates the gear your in went off. The low fuel light is also on. I check all the fuses - OK. I began to research this and found a TSB #3777 shows this issue. I can't find anywhere I can print this TSB. Has anyone run into this. How did you fix it?
Thanks
Hal
Old Nov 7, 2012 | 10:11 PM
99blazer83's Avatar
I know this is a pretty old thread but if u are still a member on here, did u ever fix this problem? I have the EXACT same issue with my 99 blazer. fuel gauge, temp gauge, low fuel light, battery light and the gear indicator. if u solved this problem PLEASE tell me how. thanks
Old Jan 4, 2014 | 2:29 PM
kcorp's Avatar
Default Did either of you figure this out?
I know this was over a year ago. Dealing with exact same problem. Thanks.
Old Nov 24, 2014 | 7:42 AM
jimdianne12's Avatar
Smile booger12
Thanks
Hal
I have same problem
Old Jun 20, 2015 | 8:51 PM
gordonhancock2's Avatar
I have a 1999 blazer the fuel gage went out, temp gage, and the battery light stays on. 80000 miles are on it as well... i need heeeelp!!!!
Old Jun 26, 2015 | 6:22 PM
thx569's Avatar
2003 S10 4.3
I have the same issue with fuel lite, gauge and check engine lite. Someone out there must have the clues to fix this.
I've done the fuses, replaced the fuel sender. There seems to be a break in the wiring somewhere.
As an aside, I just finished replacing the intake gaskets. Is there anything on the engine that would be a possible cause?
P
santa6
Jun 23, 2013 2:14 PM
olemattinson
K5 Blazer
May 9, 2012 9:19 PM
Redd Dogg
May 9, 2012 6:31 PM
wrxsubaruwrx
Dec 3, 2006 12:33 PM
