S-10 & Blazer 1982-2005
Fuel gauge on with engine off
Old Sep 12, 2012 | 7:18 AM
Discus's Avatar
Default Fuel gauge on with engine off
Help. 3 minutes after engine is off, key is removed, door has been opened & closed...The fuel gauge clicks on and begins draining the battery. If I open door the gauge shuts down. 3 minutes later the fuel gauges registers fuel, battery drains. Anyone had to solve this problem? Thanks for the help.
Old Sep 12, 2012 | 7:53 AM
Jeff Collision's Avatar
It may be the contacts in the switch are going bad or the timing of the switch is out. So, pop the switch out and check it.
Old Sep 13, 2012 | 10:21 AM
Discus's Avatar
Thanks Jeff. Are you referring to the ignition switch or the fuel gauge?
My concern is...with the engine off and the key removed...the battery is being drained. The indication of power being used is the fuel gauge needle on the dash. I actually hear a click when the gauge comes on. I appreciate any feedback.
JohnG20
Oct 12, 2013 11:26 PM
santa6
Jun 23, 2013 2:14 PM
hfdff
Jul 26, 2010 9:09 PM
scottkern3
Dec 7, 2009 7:53 PM
wrxsubaruwrx
Dec 3, 2006 12:33 PM
