Fuel Problem on 91 S-10
I have just swapped motors in a 91 S-10 with a 2,5 L with a motor from an 88 w/ a 2.5 L. Every thing is hooked up and I have one problem. When the key is turned on the injector pumps a huge amount of fuel into the throttle body. The motor will try to start after you have cranked it for 15-20 seconds then wham the injector dumps a giant squirt of fuel and it dies. I cannot figure out what is causing this. I changed the fuel pump due to a prior problem with no fuel at the throttle body. I have changed the throttle body pressure regulator, the throttle position sensor and the injector. Please help, I am lost
hunter10220
May 18, 2011 8:37 PM
harascho
May 11, 2009 2:10 AM
ross_boss08
Aug 4, 2008 2:41 PM
