S-10 & Blazer 1982-2005
Fuel Pump Replacement
Old Sep 19, 2008 | 5:53 AM
TIGERZ's Avatar
Default Fuel Pump Replacement
Im in the middle of replacing the fuel pump on a friends 2000 sonoma. You dont replace the pump, you have to replace the ENTIRE assembly. Anyway, its not held on like the fuel pump in my camaro or silverado. Its held in place by a very large snap ring. The problem is this: I cant get the pump to go down far enough for clearance for the snap ring to bolt in. I need like an extra half inch.
ive doubled checked the part and its the right one.
Old Sep 19, 2008 | 4:29 PM
shawnvw's Avatar
Banned
Default RE: Fuel Pump Replacement
put the pumps side by side, and press down on them to see if the springs depress the same amount
Old Sep 20, 2008 | 4:18 AM
TIGERZ's Avatar
i figured it out.
the O-ring is a VERY tight fit.
im gonna head to autozone in the morning and see if they have some sort of special grease i can use.
mangomanj
Aug 17, 2014 9:51 PM
BRB
Dec 28, 2012 8:34 PM
hunter10220
May 18, 2011 8:37 PM
b45701
Apr 1, 2007 2:11 PM
