S-10 & Blazer 1982-2005
Bleeding brakes on 1998 S-10 after rear line break...
Old Apr 16, 2008 | 11:24 AM
KevinCarter's Avatar
Default Bleeding brakes on 1998 S-10 after rear line break...
Hi,
I am having a brake bleeding problem on an S-10 (1998) 2WD 4.3L. I had the brake line that goes from the Master cylinder to the rear axle blow due to rust. I had no choice but to drive it with only front brakes for a few days and now that the line is replaced we can't get fluid to bleed into the line....I suspected the P-Value but we tried reseting it by opening the front bleed screw and still nothing....
Is there a special procedure for this truck beyond the normal bleed procedure?
Any help is appreciated.
Cheers,
Kevin
Old Apr 16, 2008 | 2:16 PM
EvansBlue's Avatar
Default RE: Bleeding brakes on 1998 S-10 after rear line break...
No. Just like normal.
Old Sep 21, 2008 | 4:54 AM
dmhoo29's Avatar
Little late.There's a recall for that issue.Mine did the same thing.They will still honor it if the repsir has not been done.
Kenny Kiefer
Feb 13, 2011 1:39 PM
AndrewSE
Mar 26, 2010 8:46 PM
GJ750_WV
Sep 13, 2009 11:37 PM
jljbtm
Apr 6, 2009 5:43 PM
sixpack_sid
Mar 3, 2009 11:01 PM
