S-10 & Blazer 1982-2005
Headlights - No Power on Drivers side HIGH BEAM
Old Nov 3, 2014 | 5:51 PM
Mark97213's Avatar
Default Headlights - No Power on Drivers side HIGH BEAM
Hello all. I'm hoping someone has some insight on this as it has me baffled. All lights operate except for the drivers side (LH) High Beam. Replaced bulb, no go; no power seems to be coming to the wiring using a test light. The only other thing not working on the truck related to lighting is the Dome light that won't shut off but will turn on/off using the remote keyless entry. Otherwise I have to use the Dome Override switch. Not sure if the High Beam is related to this circuitry.
Old Nov 6, 2014 | 1:04 PM
ThatChevyGuy's Avatar
I would check with a voltmeter to see where you are losing current.
blueinterceptor
Jan 5, 2015 8:05 AM
otis_xing
Apr 13, 2013 2:31 PM
Klimbo
Jul 10, 2012 9:44 PM
rlsam123
Jan 4, 2012 9:39 PM
shant
Feb 23, 2011 9:08 PM
